					Originally Posted by jsceash  Did you ever install that unit? I looked at my 2.7L motor in the garage. I have about 6.5" under the manifold. Was there more clearance in the 2003-04 engines than earlier models. Do the opening line up the same? |
not installed yet - i am waiting until the next time i flush the coolant. the pic below shows the 986 S cooler in a 2000 3.2 S. the 3.2 and 2.7 are the same manifold regardless of year. the 997 oil cooler is 1/2" taller. i do not see any reason why it would not fit. there might be a bit of interference with the vent tube at the top, but it is easily bent to fit.
