Old 03-18-2017, 12:38 PM   #1
Coaster
Coaster's Avatar
Replaced brake pads and rotors this week. Used Hawk ceramics to hopefully reduce brake dust. I ended up buying new dampeners since mine looked a little worn but not positive I needed new ones ($170 for all four corners). Also flushed (most of) the system. First time I've ever had it up on four jack stands too. I'm not entirely comfortable with getting all four wheels up yet, car leans quite a bit when jacking it up lol. Also did not bleed the clutch. I finally found the bleed nipple but simply could not reach it since car was on lowest settings of the jacks and didn't feel safe enough to squeeze under the car to get to it.
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
