I'd recommend taking the carpet out and letting it air dry out of direct sunlight for a week. That's the only way I've had luck drying carpet out. My car was also a flood damaged IAAI purchase. It sat for 5 hot Texas summer months before I had a chance to pull the carpet and it still had tons of water in the insulation after all that time. Check your drain holes also because 90% of all flood damaged boxsters are caused by clogged drain holes or a hole in the top/window.
Woody
