Old 03-17-2017, 04:13 PM   #261
itsnotanova
Sorry if you're waiting on me to pull parts. I needed to get this done so I can get my car out of the shop. Finished with the skid plate. I went ahead and added a rear attachment to help keep the pan from bouncing around and causing metal fatigue. It was real simple as there was already a tapped hole right there. I liked using that spot versus the side mounts as it seemed a lot more robust. I painted the pan red but it's not like anyone can see it. Overall I'm happy with the outcome because it should give me a little relief from worrying about hitting stuff. It also doesn't add much weight. It is easy to make one for yourself and all you really need is a drill, jig saw and way to bend the metal. I used a bench vice to do the bending.
Woody
