Thread: Oil Coolers?
Old 03-17-2017, 01:33 PM   #11
JFP in PA
Originally Posted by Need_for_speed View Post
Awesome! Not sure where I read that the S cooler wouldn't fit, but I probably got it wrong anyway. Thanks JFP, that is certainly a really easy solution. I haven't checked Pelican to see if they have any S coolers available. Can I assume that this component is free from wear issues, in which case I can buy a used part (hello Woody)?
Also, there's this, but not sure if it fits:
Large Oil to Water Heat Exchanger Kit - Parts & Upgrades - Products LN Engineering
Am I on target with my analysis that overheating is the primary issue, or should I still consider a deep sump or accusump?
RK, thanks for the article. That is a very elegant solution.
We always use new coolers as you have no idea of the condition of used stuff. And we do not use aftermarket coolers like Pelican sells, we have not had any luck with them.
If you intend to do serious track time, you will need a deeper sump, baffles, an Accusump system, and probably a third radiator as well.
That LN unit is not a factory fit system, it is a remote mount system using water hoses and AN lines for the oil.
