Rotating track tires?
My Hankook RS-3s are showing much more wear on the outside but all in all are doing pretty well after 6-7 DE events and 3 AutoXs.
I'm thinking of switching left for right in both front and rears, so that I can wear out the other side and maybe extend the life of these great tires.
Any issue with doing this? Will I loose traction if I do that?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
