Old 03-15-2017, 09:17 PM   #1
particlewave
Originally Posted by oldskool73 View Post
related to this, have you guys figured out how to unclip the connection down by the indicator light (with the 2 prongs, where it goes down through the housing to the outside)? looks like it should be able to unclip and/or twist or something to remove, but I've had no luck. should I just desolder them from the posts?
Yes, it unplugs. If you look closely, there are small nipples that protrude through slots, but one is hidden by the housing. If you loosen the one you can see (again, with s small jeweler's flat head), then it will unplug.
I always reuse the h7 connectors for a cleaner look.
