Old 03-15-2017, 05:33 PM   #1
Need_for_speed
Originally Posted by Keith box 02 View Post
Dumb butt I guess I did not know the radiator fluid was clear. What should I check?
There is a coolant overflow tube right in front of the rear tire on the passenger side. One of the more common conditions that would cause coolant to overflow is air in the cooling system, usually from an insufficient bleed. Have you had a coolant system flush recently? Do you have a CEL? Is the car overheating?
Need_for_speed is offline   Reply With Quote
