Old 03-14-2017, 01:45 PM   #21
JFP in PA
Originally Posted by WorkInProgressK View Post
I appreciate that you help the community. I won't argue that its the only reason why I keep participating. My field of work require thorough study of every situation and we can't forget the big picture. I am just trying to say that the solution isn't always clear cut. You might solve 1 issue and cause two problems. Just like IMS issues is to Porsche cutting cost on engine head castings .
As a friendly reminder, re-read yourself on the heater core part. Heaters(cabin radiator) and engine are on a closed loop system. No thermostat in between. In the morning, you will feel heat at around 100F on the cluster.
The heater uses a small bypass from the engine, but when the thermostat opens, more warm water is in motion within the cooling system and the engine, heat comes up in greater amounts within the cabin; so the thermostat does affect how much and how soon you sense heat coming from the car.
And, regardless of what you do for a living, it is never a good idea to look down your nose at anyone.......................
