I'm guessing this is on the pass side (USA) of the car?? If so, then there is a lot of things that could be leaking above there and that tensioner probably isn't the likely culprit.
Oil can be leaking from all of these places. AOS, Flex Pipe & oil fill pipe.
You can see the mess below all of then before it gets to the tensioner area.
