Old 03-14-2017, 09:09 AM   #15
WorkInProgressK
Unless you track your car often I would suggest not running the lower temp thermostat. Someone starting by "it is actually a fact" and doesn't provide sources isn't credible. Will it break your car? No. Will it give you more power? Maybe for a short period. Most of you change your oil way too often already and cover the consequence of running a lower temp thermostat. If you want to start throwing your money away go for it.
About the water pump, I would love to see pictures of the "chewed up area". They are centrifugal pumps and if you catch the mild leak, you shouldn't build enough play to have contact. Even if there is contact, that gap will provide more flow at higher RPMS since you will be making the path wider.
Source:"http://www.mcnallyinstitute.com/12-html/12-06.html" It talks about trimming the impaller to make more gap, but if the cavity gets bigger it should have the same effect.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
