Old 03-14-2017, 05:19 AM   #1
Cbonilla
Removing the seat is no big deal. Four torx head screws. If you don't have a female Torx socket a standard socket will work and not bigger the screw heads too badly. Disconnect the battery first or you will trigger an air bag light. The hardest part is figuring out how to undo the plug from the seat into the immobilized. If I recall correctly, you have to lift and remove a tab and then slide the plug apart. May be able to find a video on how to open this
Cbonilla is offline   Reply With Quote
