Old 03-11-2017, 12:19 PM   #1
AviSalem
New Battery Cable, Windows and Top not Working
Hi All,
I changed one of my battery cables that had completely snapped off from where it connects to the power distributor. After putting a new cable on, car starts up fine, door lights and interior lights work, radio, door lock, air conditioner all work. The windows will drop down and go back up when I open and close the doors, but will not operate from my switches. The top will not do anything either now. I tried turning and holding the key in the door in the unlock position to see if the windows would drop like that, no such luck. Any ideas? I completely disconnected the battery and connected the two cables together to discharge the car, and reconnected after 15 minutes to see if it "Resets", nothing changed. Any other advice would be helpful, I checked all the fuses, thinking it was a fuse problem, they are all good. Even tested the voltage on C3 and D1, both good. Please help!!
AviSalem is offline   Reply With Quote
