Old 03-10-2017, 06:08 PM   #3
Muskoka Minute
Muskoka Minute's Avatar
Both may be correct if #1 assumes you will also change the heads &
(We will have to change everything as if it was a long block)
(fuel rails, wiring harness, plenums, throttle body etc)
Then it will work
So just so I understand this correctly..
To make this work you have to change the heads for this to work no matter what??
just trying to clarify.
My Beast 2004 Boxster SE #0174
- 3.8 with all the internal goodies, Under-mount Pulley, IPD Plenum, 996 Intake, Softronic Tune, 987 Factory Sport Exhaust, skid plates, IMS solution, Ohlins R&T, RSS Toe Links, Camber Plates, Michelin Pilot Super Sport on all 4 corners, Alpine Double Din c/w new speakers & amps.
Muskoka Minute is offline   Reply With Quote
