Check the tires for a delaminated steel belt. Had a tire go bad once and it felt just like that. You can check the DOT code on the side wall for the manufacture date, anything over 6 years is suspect. Even if the tread looks good, an old tire can still go bad. It's not the amount of wear that matters, it's how old the tire is. Steel belted tires are notorious for going bad, you can see all the tire treads on the freeways from all of the failures.
