Thread: Cps fail?
Old 03-08-2017, 09:23 AM   #16
flouese
flouese's Avatar
A FP relay is a common spare carried in older Porsches. They do not always completely fail and can cause intermittent issues such as yours. The problem is you can check fuel pressure and it works fine and can cause you to look elsewhere. If you haven't already I'd replace it with a new one, they're cheap <$20.
Thanks for the input. I will order the relay today. Will follow up after install to let you know if that fixed the problem.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
