Old 03-06-2017, 01:31 PM   #1
tjwebber17
Overheating and No Heater
Hi guys please help! My 1998 Porsche Boxster auto trans 134k miles. It started when the dash tachometer and speedometer acting up and suddenly stop working only thing working is the water temp and the gas (car still drives fine) after 20 mins of driving the car got overheated so I pulled over and saw coolant leaking. I got the car towed and inspected the car the next day. I found out the reason why It got overheated because the serpentine belt retracted due to one of the idler pulley gave up. Thank God no oil and coolant mixture but the coolant reservoir got cracked hence it was leaking when It got overheated. I ordered the parts right away (coolant reservoir, serpentine belt, idler pulley) and installed them. I started the car and starts right up but the tach and speedo still not working (disconnected the tach and connected back and checked the fuse and all looks good) but still not working. After 20 mins of idle car temp is still fine but when I turned on the Heater no hot air coming out (AC works fine). I took the car for a short drive then I noticed temp goes up to 200 so I went back home immediately. Check engine light is on so I scanned it and shows P0117 (Engine coolant temperature sensor 1 Circuit low) So I bought a coolant temperature sensor and replaced them right away (part no. 99660640501). Started the car and it's same thing got temp goes up after 20-30 mins of idle. I'm thinking to replace water pump and thermostat but any tips with this issue is highly appreciated. Thanks!
tjwebber17 is offline   Reply With Quote
