Old 03-06-2017, 06:34 AM   #11
flouese
flouese's Avatar
That indicates the CPS is defective.
Here is the definitive test from JFP:
"Remove the CPS sensor connector, connect your multimeter to pin #1 and pin#2, at 68F it should read 0.8-1.0K ohms; then connect the multimeter to pin #1 and pin #3 and it should read infinite ohms; if it does not read correctly in either range, can the sensor and replace it."
What does "at 68F" mean? Are you referring to temperature? I am standing by for ridicule, but I am also suffering from starting issues. Unfortunately I posted the CPS failure post before I saw this one.
99 Boxster base
1966 912 3 gauge
flouese is offline   Reply With Quote
