Old 03-02-2017, 12:29 PM   #10
Anker
Originally Posted by bwdz View Post
An independent shop is not likely using OEM parts. What happens is they have to mark up the parts, if the rotor costs them $80, it costs you $149.95 etc... That is what they have to do to stay in business but for something as easy as brakes it is not necessary to take it to a shop. To replace the rotors over just the pads it is 3 more bolts, 2 caliper bracket and one rotor screw.
Bad example. Porsche doesn't manufacture these parts themselves, but purchase them from several manufacturers and then mark them up significantly. You can purchase these parts directly from the supplier or from a distributor for significantly less money, often half of what Porsche sells exactly the same part for. This practice is called relabeling.
In many cases you can purchase parts that are superior to the Porsche parts for less money. The indie I use specializes in auto sports upgrades. They do NOT use inferior parts.
1941 Dodge Luxury Liner Coupe
