Old 03-01-2017, 09:11 PM   #12
Boxstard
I'm still thinking about your sway bar. Plus, any chance you can sell me the part of wiring harness? I need one male connector with pigtail wiring for the back oxygen sensor, that is mounted with rubber grommet in the back corner of trunk under the carpet. Mine has broken tabs so female connector from the sensor does not catch and lock in place. Another is the square 2-pin connector (Bosch style? with locking wire around) with pigtail wiring for the solenoid valve actuating the secondary air injection vacuum switch valve. I think the fuel injectors use the same connectors. I need 4-5 inch of wires snipped off the harness, so I can solder them to my harnesses. Let me know if you can help. Thanks!
