Thread: Heater problem
Old 03-01-2017, 04:35 AM   #1
jeeper31
jeeper31's Avatar
Originally Posted by paulofto View Post
Okay, so the heat was fine before you changed the pump and thermostat? Not to discount 78F350 but I would venture that the heat issue has something to do with the pump and/or thermostat. General rule of thumb; look at what you last did before the issue arose. Air in the system, coolant level, DOA faulty thermostat or pump could all be part of it. Some questions; Does the temperature get to ~180 F? Does it say there? Does it rise and/or fall when the heater is activated?
I think the heat wasn't as good as it should be before I did the water pump.
You have an air pocket (WAG)
Airlift or use the burp valve.Search for more.Pelican has the diy
If I had an air pocket wouldn't the heat be intermittent? Start off hot then go cool for a bit then back to hot?
jeeper31 is offline   Reply With Quote
