Old 02-28-2017, 02:01 PM   #1
Gilles
If memory serves, the air bag module grounds through the wiring harness as well as the module chassis itself. A good wiring diagram would be essential. You didn't say what year the car is, but most years the module is located in the area beneath the radio in the center console. You need to be extremely careful working on this module and its wiring as even static can get you a face full of airbag.
Thanks JPF, the car is a '07 CS
If I 'remember correctly' the only ground I disconnected was a thick black cable from the frame to the bank 1 cam covet.
However, that was around Oct-Nov and sometimes I have a hard time remembering the details of the completion two weeks ago.. :-(
But before I dig into the console (as that section) was not related to the repairs, I should check for a loose connector around the driver's side engine compartment..
I am not sure if I have the wiring diagram on the 'shop manual' something else to check.
