Old 02-28-2017, 11:55 AM   #1
Gilles
Airbag ground connectors?
I feel comfortable working on my car but when it involves any of the electrical stuff I am completely lost..
Background: My car has been back on the road for three days after a five months hiatus that required a gearbox repair, overhauling the coil overs and also fixing a pesky oil leak from the bank one cam cover (so far no more leaks, knock on wood..).
After putting the car together I got an airbag red warning light on the dash, and according to the Durametric the P/N 997.618.218.08 (Airbag Module) is either internally shorted out or has a faulty ground connection. (I was not able to turn this warning light off)
For the various repairs mentioned above, I didn’t touched anything related to the steering wheel, but I did lowered the engine about 8” for the valve cover to clear the frame.. but remember being careful not to pull any connectors.
Does someone knows where can I check the ground connections for the airbag before ordering a pretty expensive part?
Thank you in advance for your comments!
