Thread: CEL/Codes Help
Old 02-28-2017, 06:58 AM   #2
jeeper31
jeeper31's Avatar
Originally Posted by p3230 View Post
If you google the codes that is what I got
P1313 Misfire, Cylinder 1, Emission Relevant
P1314 Misfire, Cylinder 2, Emission Relevant
P1316 Misfire, Cylinder 4, Emission Relevant
P1318 Misfire, Cylinder 6, Emission Relevant
P1319 Misfire, Emission Relevant
Most likely causes:
- Fouled, faulty or incorrect
- Contact resistance
- Loose contacts
Have you changed the spark plugs recently?
Correct spark plugs?
You should check the continuity of the flywheel sensor.
Check for cracked ignition coils
Thanks Frank. I got the car about three years ago. The previous owner said he just changed the plugs but who knows. I haven't changed them.
It seems strange that both cylinders are misfiring at the same time all of a sudden. You would think one might go at a time.
jeeper31 is offline   Reply With Quote
