Thread: CEL/Codes Help
Old 02-28-2017, 06:43 AM   #1
p3230
p3230's Avatar
If you google the codes that is what I got
P1313 Misfire, Cylinder 1, Emission Relevant
P1314 Misfire, Cylinder 2, Emission Relevant
P1316 Misfire, Cylinder 4, Emission Relevant
P1318 Misfire, Cylinder 6, Emission Relevant
P1319 Misfire, Emission Relevant
Most likely causes:
- Fouled, faulty or incorrect
- Contact resistance
- Loose contacts
Have you changed the spark plugs recently?
Correct spark plugs?
You should check the continuity of the flywheel sensor.
Check for cracked ignition coils
Frank
p3230 is offline   Reply With Quote
