Hey Tom, nice repair work. You might want to consider mounting the helper/tender spring up top, with main spring down below. The reason is to reduce unsprung weight.
Keep up the good work. Can't believe you're going for a 2-week turnaround on this! Doesn't it take about that long to dial-in the alignment settings?
Hope everything gets pulled straight so you can get the right alignment characteristics!
