Old 02-26-2017, 07:54 AM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
Originally Posted by Onelbil View Post
... Question is, I have tiptronic and these are manual. What is involved to use a manual engine and match it to a driving tiptronic? (Meaning I have all the parts for the tiptronic) do I need to switch some stuff over or are the engines just different? ...
I swapped a manual engine into my '01 tiptronic. Most of it is the same, but there are a few things that you need to keep from the original engine.
*The wiring harness. The tiptronic wiring harness is integrated into the engine harness. It is a lot easier to just swap the harness over than try to separate them.
*The vacuum system. There is a vacuum line from the engine that goes to a change over valve on the tiptronic transmission. The brake booster vacuum line is different, connects to the opposite end of the engine and has a venturi connection.
*The alternator and starter are a little different, but will function fine in either engine.
An old post from when I did the swap: Maint to do? Swapping in a used 2.7
