Old 02-20-2017, 10:51 PM   #1
BirdDog
BirdDog's Avatar
The switch for the frunk light is in the latch mechanism.
When I got my Boxster (3.5 years ago), the light worked intermittently. I shot the latch mechanism with some white lithium lube (intended for brakes) and the light now comes on every time.
I would try spraying some lubricant down into the latch mechanism and closing and opening the frunk lid a few times. I bet that will get the light working again...
Note: by lubricant I don't mean WD-40. That might work short term, but it's not really a lubricant. You can use WD-40 to loosen things up, but follow up with a real lubricant like 3-in-1 oil. I used spray lithium grease because it won't drip off with high heat.
2001 Boxster S - Speed Yellow, Black Leather, Tiptronic, Jake Raby rebuilt 3.2 with IMS Solution
BirdDog is offline   Reply With Quote
