Old 02-20-2017, 07:10 PM   #10
The Radium King
The Radium King's Avatar
The 997 cooler is too tall to fit under the Boxster intake. The 997 intake is a couple inches higher than the ones used in the Boxster, and the "S" cooler is as tall as you can go without major difficulties with a Boxster intake.
S cooler is about 4.25", 997 cooler is 4.75" - about 15 mm larger. enough room under the S manifold; you may have to trim the vent tube a bit.
