On each side of the car, behind sits a "Top transmission". The top transition controls the movement of both the top and the camshell. In your case, the arms that attach your top to the transmission have become disconnected.
Put your top up and open the clamshell. Look at the rod that connects the clamshell to the transmission. You should see another similar rod that is attached to your top but is disconnected from the transmission. The plastic pivot is known to fail so see if your is busted or not.
