225 35 19 will fit a 9 wide fine. Very slight stretch but it's within specs.
You'll potentially have 2 issues with a 235. The diameter is about 25.5 which will make a slow car slower. You're going the wrong way in diameter.
Depending on the height of your car and offset, with a 235 can/will rub when you turn. At almost full lock, it can/will rub on the wheel liner.
