Originally Posted by geraintthomas
If you could keep me in the loop with where you get to, I'd be really greatful!
If I split my lights again I would dremmel off part of the projector shrouds to allow the longer sidelight bulb and make it more visible. A bulb with a lens on it would then be fine I think. Seems the current clearance is about 38mm and the bulb I bought was 45mm long. Ordered the 15w which is 28mm so will see how that is when it arrives.
Sent from my ONE A2003 using Tapatalk
