Old 02-17-2017, 01:11 AM   #1
auBoxster
auBoxster's Avatar
Quick update - figured out that the problem is probably too low idle, or at least that's why it is doing it when it warms up... when hot/warm engine is idling at 650 rpm !!!
That's not right and the noise/clatter goes away as soon as the idle rises above 750rpm. I think the standard idle speed is around 800 right?
So my guess is that I've got an air/vacuum leak or something like that. I wish Durametric has a simple AFR value that you can poll to figure out if the AFR is wrong for idle (confirming the air leak)...
Any other thoughts??
auBoxster is offline   Reply With Quote
