Old 02-16-2017, 05:37 PM   #2
pussywillow1972
Well where did you get this wheel? It appears from the pic that it was in an accident and the bottom and left spoke are possibly bent. If you can take some more pics with better detail. If the wheel is straight then the thin metal frame the airbag is attached to is bent. You can remove that piece and lay on a flat surface, then carefully bend back into shape or get a new one.
I got it on ebay. I'll remove the carrier like you suggest and see if it's bent. The wheel itself looks ok.
pussywillow1972 is offline   Reply With Quote
