Old 02-16-2017, 03:48 PM   #6
TeamOxford
Damn Yankee
TeamOxford's Avatar
Originally Posted by jay2015 View Post
Hi All,
When I press button on the key or hit the Trunk opening button, I hear the clicks and it seems like the trunk is opening. However, it does not open enough to insert fingers in to slide the middle lock/lever.
It does create some space on the sides where I can lift it up by an inch or so and then I can slide my finger to slide the lever.
Any ideas or tips to troubleshoot this issue will be greatly appreciated.
Regards,
Jay
Common and classic symptoms of a worn out spring in the hood release. The entire assembly must be replaced. Easy DYI job. You can buy a new one, or get a used one from a recycler like Woody.
Just sayin'...........
TO
