Old 02-16-2017, 04:22 AM   #360
RichRobby
Originally Posted by RichRobby View Post
Ger
That's a shame about the sidelights as I've done just the same however I took my DRL feed from the fuse box and the sidelights still work, albeit very dim. I see on ebay that you can get 15 watt and even massive 50 watt T10 fitment bulbs so maybe that will solve the problem?
Sent from my ONE A2003 using Tapatalk
I went ahead and bought 50 watt LED T10 bulbs to brighten up the obscured original sidelight but unfortunately they are too long and hit the projector shroud. They would have been great as they had a lens on them and would be super bright. Will have to find another use for them or try to return them.
Trying to find out the physical length of some 15 watt ones now.
I guess it would be useful to know how bright they need to be to pass an MOT?
Would much prefer to find a solution that kept the wiring original rather than go down the route of having to use the foglights.
RichRobby is offline   Reply With Quote
