Old 02-15-2017, 12:47 PM   #2
JFP in PA
Originally Posted by Vfrealtor405 View Post
Hello Friends,
Recently acquired a Boxster S with a Key FOB in non working condition. Followed and researched some YouTube videos and was able to solder on a working button that was defective. My FOB still does not work, even tried the reset technique in the manual. Unlocked my door via the key manually and pressed #1 button. Still no dice. Is there a transmitter box in the vehicle I need to reset or plug antenna? My key FOB diode does blink red and it has a fresh battery. Am I missing something here?
Yes, the car must be programmed to accept the fob, and in order to do that, you need the coding tag that came with it from the factory. No tag, no programming.
