Thread: Ims and clutch
Old 02-15-2017, 12:30 AM   #2
alcubot
Thank you very much to all of you frinds, i've a manual 6-speed transmission.
I'll do the job with an expert mechanic, but i want to choose the correct spares with your help.
Just 3 questions:
#1
i've read this article to determine which Bearing is Inside my Engine:
Pelican Technical Article: Boxster Intermediate Shaft Bearing Replacement and Upgrade (IMS) - 986 Boxster (1997-04) - 987 Boxster (2005-06)
So i assume that i've a Double Row Bearing, you confirm me?
#2
it's a good idea (when we operate to the clutch) change only the L part in this image if the other things are ok?
http://cdn4.pelicanparts.com/techarticles/Boxster_Tech/44-TRANS-Clutch/images_small/Pic03.jpg
#3
I need the gasket between the engine and the transmission and the oil Cup one, is there anything in particular to be mounted?
Thank you very mutch in advice.
A.
Hi, i'm Antonio from Italy.
Boxter 986 S Year: 1999
alcubot is offline   Reply With Quote
