Old 02-14-2017, 10:08 AM   #1
kk2002s
kk2002s's Avatar
I did exactly the same steps you did except I did 2 distilled water flushes because I to had Green coolant. I never got more than 4 - 5 gals out each time.
Once you get the vacuum up before refill, let it stand for a couple minutes. If it holds the recommended vacuum level, that should indicate you have no leaks.
I was prepared for up to 6 gals replace with 3 gals pink coolant and 3 gals of distilled water.
Now I have about 2 gals of 50/50 left over
Seal Grey
