Did not get much track time other than doing some coaching with friends. Car had a grinding noise from the rear on right hand turns under acceleration. I had removed, inspected and repacked the CV's prior to the event, so probably not the cause. Four wheel bearings will be here tomorrow.
Sway bars, GT3 LCA's, engine and trans mounts, and much more are on the way.
Still lots of work to do. Pushed the cage install back so that I will have time to get to the wiring before it goes in.
Tim
1998 986 (3.2L and 6-speed transmission added)
1999 986 (SPB)
1999 986 (parts car)
2001 986 S (parts car)
