Old 02-14-2017, 09:27 AM   #3
dsallean
What was the minimum vacuum reading you maintained with the AIrlift throughout the entire refill process?
That may be the problem.
I haven't used the airlift yet, so the system is still empty. I actually just kind of ran out of time this weekend so I thought I would stop here and get back to filling the system after some more checking with the experts.
Short of standing the car on end and shaking it a couple of times, you are not going to get all the coolant out. The best you are going to get doing a gravity drain is around 80-85% of the system's capacity. Refilling the car with distilled water, then running it for a bit before draining will help get rid of any remaining old coolant.
Thanks JFP. I'll do that and cross my fingers that I haven't screwed anything up with all the work I have done recently!
dsallean is offline   Reply With Quote
