I'm reviving this ancient thread because there's so much information here to read and I'm kind of stuck with my 986 window problem. I replaced my battery last weekend, and afterwards the driver's window is acting a tad squirrely. The window goes up and down fine, but when I shut the door from the outside the window doesn't drop quite far enough -- making contact with the top frame. As a result, the door doesn't close properly.
The window drops as it should (the drop-down feature as you open/close the door) but as I shut the door the window pops back to its home position before the door is closed. It's as if the timing is off or something. Is the a symptom of the faulty regulator? It's just odd that it all started happening when the battery was replaced. (Also, for some reason by windshield washer pump stopped working).
1999 Boxster; Arctic Silver with Metropol Blue top. No mods... yet.
