Technical question, re: placement and wiring of second bulb after outer lense is removed and my inner burned lense also removed. I see the projector mounted in the top bulb hole, that`s straight forward. My question is what is the preferred method of the lower bulb hole Since the Bi-Zenon does both high and low beam and the inner lense is removed, is the original h7 bulb simply reinserted and connected to seal the assembly and eliminate bulb out dash warning light or is the hole filled with a blank to eliminate glare from h7 bulb. Thanks in advance for any help.
