Old 02-10-2017, 07:21 PM   #9
jcslocum
Project Addicted
jcslocum's Avatar
The CPS is on the right/pass side, in a slot between the trans and the engine. I have pics but can't get to them right now. If doing it on the ground, I think it might be easiest to pull the rear wheel and go at it that way. It will be in front of the rear wheel straight in, held in with a Allen bolt. The plug is on the back of the area near the cam plugs. The wire is like 14 inches long.
As I recall, there is a BMW one that is exactly the same in the $55 range. My memory on this might be bad tho. Do a google search and good luck.
______
Jon
1966 912, 1976 911
1986 944, 2000 Boxster
