Old 02-09-2017, 04:25 PM   #4
The Radium King
The Radium King's Avatar
instead of rear uprights all you need are the rear hubs (axles different diameter). when you get the 5-speed just make sure you get the shift cables, slave cyl, axles, hubs and mounting brackets with it. presume you would be doing clutch and pressure plate regardless of what transmission. probably rear wheel bearings too when you change the hubs.
