Old 02-09-2017, 02:16 PM   #29
Smallblock454
that's odd. with track pads, where heating is most important, you can't even fit dampers.
We've used EBC orange stuff with OEM dampers and without any fitting problems. Personally i use Brembo HP 2000 with OEM dampers and any problems.
the dampers are not attached to the pistons, so unsure how the pistons pull the pads back.
Correct. But what happens if the pad heats up? Look at the design - especially of the front dampers.
Regards, Markus
