Old 02-09-2017, 07:37 AM   #21
WorkInProgressK
The weakness in our relay test was that nobody insisted on wiggling the coil pins during the resistance test. The relay tested perfectly.
It is possible that the loose pin was caused by an overheating coil in the relay or arcing contacts ? Hence the suggestion to feel if it got hot.
Anyone got a circuit diagram for the fuel pump fuse - just to close the loop ? The 5th pin, the small one is the oddity.
Well I did say to bypass the fuel pump relay entirely. But you are right that you would not have know what was at fault on the relay unless you opened it.
Wow, that tab. It just looks like porsche decided you couldn't use a standard 30 amp bosch relay which i am certain is identical inside. Their solution is to change one tab to a smaller one and turn one 90deg.
If you have a soldering iron, you could open it up and re-solder the joints.
2001 Boxster S (SOLD)
1991 Nissan Silvia "K"(Forgotten somewhere in Canada)
1989 240sx (Track car)
1987 325IS (Soon to be Spec E30 racecar)
2001 GSXR-600 (Almost warm outside!)
WorkInProgressK is offline   Reply With Quote
