Old 02-08-2017, 09:23 AM   #1
dsmithwc04
2001 Boxster S ONLY 26k miles! IMS retro complete!
I'm the second owner of this immaculate 2001 Porsche Boxster S 6speed manual with only 26k miles. All the maintenance below was completed in the last 2 weeks. Redstone Performance Engineering in Lebanon, IN did the rear main seal, IMS retro install and coolant flush.
I have both original keys plus the valet key as well as original window sticker, manuals, and order/build sheets from when the previous owner ordered the car.
Cabin Air Filter: Inspected and replaced with charcoal embedded Mann filter
Engine: Inspected and replaced Mahle air filter. Hoses and belts inspected for cracks. Oil and oil filter replaced with Hengst filter and Mobil 1 0w40 Synthetic. New drain plug washer installed. Slight oil seapage between transmission and engine. Oil filter inspected for debris with none present.
Throttle body: Removed and inspected. Slight residue buildup on butterfly. Throttle body and plenum cleaned inside and out. Computer calibration completed.
Oil/air separator: No abnormal oil residue in throttle body or plenum.
Spark Plugs: Replaced with Bosch 7413 plugs.
Coil pack check: Inspected for cracks.
Engine bay check: Cleaned with damp rag and inspected.
Battery check: Battery was load tested. New battery installed.
Brake system check: Hydraulic fluid flushed. Pads and rotor thickness inspected. Caliper piston seals inspected. Master cylinder tested. Brake booster tested.
Cooling system: pH tested. System checked for leaks or cracks in hoses/radiator. Coolant system flushed with G40.
Tire and wheel check: Tires show no cracking or dry rotting. Front wear aprox 75-80% remaining. Rear wear aprox 70% remaining.
Clutch condition: Engagement / slippage checked. Friction disk and flywheel checked during IMS retro kit install.
Transmission check: All gears were smooth and precise. Drive shaft boots inspected for cracks.
Convertable top conditoin: Cloth cleaned and inspected. Rear window plastic cleaned and inspected.
Rear spoiler: Functions normally.
Exhaust: Inspected for abnormalities. Exhaust hanger is making slight noise when idling at a particular RPM but not audible inside vehicle.
Body: Body inspected for dents/scratches with no obvious issues. Paint washed and waxed. Front bumper was resprayed due to small stone chips.
Glass: No obvious marks,cracks or scratches.
Interior: Audio system checked. Auto dimming mirror required replacement. Windows checked. Locks checked. Horn checked. Cruise checked. Carpet shows no obvious wear or marks. Door panels/dash shows no obvious wear or marks. Leather seats show no cracks or obvious wear. Dash guages and lights tested. Convertable power top operation checked. All electronics and buttons function. Leather cleaned and conditioned.
Suspension: All struts checked and bump tested. Bushings checked. Alignment checked.
Steering: Steering feels smooth and returns to center. Hydraulic system checked.
Misc: Original user manual, window sticker, and purchase order present. Battery storage charger present. Both original keys with valet key present.
Drive test: Throttle feels smooth with no hesitation and is strong throughout RPM band. No audible suspension noises or abnormalities over bumps. Handling feels firm during corners with a smooth but quick weight transfer as expected. Alignment satisfactory with no abnormal tendencies. Brake application has good bite and does not pull left or right. Interior road noise level normal. Audio system is normal. Convertable top operates as normal.
Asking $18,500 or best offer
Dan 317.496.4893
[IMG]20170207_134047[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_133852[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_133926[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134212[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134306[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134151[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134117[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134324[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134342[1] by dsmithwc04, on Flickr[/IMG]
[IMG]20170207_134358[1] by dsmithwc04, on Flickr[/IMG]
dsmithwc04 is offline   Reply With Quote
