Read Wayne's 996 swap -Pelican- it may give you some ideas.
You will have DME issues for sure.
Thanks for the reply Gelbster, Yes i have read the swap guide ,, from what i understand is there should be no problem as its still a 3.2 and all i would need to do is hook the brake booster vacum to the pump on the front of the cyl head .. I can deal with any physical modifications that need to be made i'm just not equipped to re program the DME
