Originally Posted by jimk04
Idler pulley solution is to gut the insides of the pump....remove impeller etc. So basically left with a bearing and a pulley...mounted in the original pump casing.
A guy in Germany had built a lw 996 c2 and took his rack to bits for manual steering. Says it is not much heavier at all but tonnes more feel.
I guess I will try this solution. There is a ps pump kicking around somewhere in my shop.
